Subject: Redirecting to a module with more parameters
vijaymoh
22 Apr 2008 1:27 PM
Is there any way we can redirect to a module with multiple parameters ?
I tried with single parameters  with editURL() and it works  fine, But i need to pass more parameters
Your suggestion will be a great help
Vijay
Forums > DotNetNuke® > DotNetNuke® Questions > Redirecting to a module with more parameters
