Subject: Passing value as querystring
nukedoubt
18 Apr 2008 3:10 PM
how could i pass a querystring value as
default.aspx?UserName=abc on a imgbutton click event in viewpage.ascx
Forums > DotNetNuke® > DotNetNuke® Questions > Passing value as querystring
