Subject: End User moving modules.
Kalagaraz
16 Apr 2008 11:28 PM
I'm wondering how easy/difficult it would be allow the end user to be able to move the modules on a page around to create their own custom look?
Thanks in advanced,
Kalagaraz
17 Apr 2008 7:29 PM
This isn't possible in DotNetNuke.
You might want to take a look at the MyProfile module from DNNFusion. It permits you to have personal pages for each user and each user can customize their particular page. The number of modules that can be placed on such pages is limited, but might be enough for you.
Forums > DotNetNuke® > DotNetNuke® Questions > End User moving modules.
