Subject: The site is unavailable....
dp6ai
16 Apr 2008 4:10 AM
Hi all,
Hoping someone can help me with this one.
I have a local install which is working fine (MSSQL 2005 std ed) so i ftp'd the directory structure to my remote server, dumped the database and restored it to the remote MSSQL Exp server and checked i could log in to the database etc. i have updated the web.config to allow for windows authentication etc Now when i connect to the site i'm getting the "This web site is unavailable, Please check back later" message.
This is really frustrating. I thought that message was usually caused by a bad connection string although it looks fine and the windows authentication is working fine.
Any help greatly appreciated.
Thanks in advance
K
16 Apr 2008 8:16 AM
If you haven't done so already, please check these tutorials:
Did you also change to portalalias table to point to the new site?
What is the URL that produces the unavailable message?  If it includes the install directory, then I would guess that there's a problem accessing the database.  Did you update both configuration strings in web.config?
Forums > DotNetNuke® > DotNetNuke® Questions > The site is unavailable....
