Subject: automaitic redirections (help)
rizwan7705
15 Apr 2008 6:25 AM
i m making a web site and i m trying to do some thing like if user trying to search their flat and they dont get anything in search result so they ll automaticly redirect to page what ll have the option to make there own flat. so please help me out in this. how to set automatic redirection thanks
Forums > DotNetNuke® > DotNetNuke® Questions > automaitic redirections (help)
