Subject: Firebug
eureka
31 Mar 2008 4:20 AM
Hi Lee
Your troubleshooting tutorial covering the Web Developer toolbar is very good.
How about accompanying it with  - troubleshooting with Firebug tutorial.
Lynn
02 Apr 2008 9:46 AM
Hi Lynn,
I haven't experimented with firebug, does it offer any additional features to the web developer toolbar?
eureka
04 Apr 2008 7:00 AM
Hi Lee
Firebug is similar to Web Developer, it is an alternative way of troubleshooting, but it goes deeper.
One of the benefits is:
It automatically informs you (via message on toolbar ) and identifies a problem you may not be aware of on any given page.
Below are some of the features you will find:
http://www.getfirebug.com/
Lynn
07 Apr 2008 4:47 AM
ok, will have a look thanks,
eureka
09 Apr 2008 7:27 PM
Great - perhaps you can include YSlow (which analyses website speed )
http://www.yahooapis.com/yslow/
10 Apr 2008 3:23 AM
hey this is a good list of resources, are there any more tools that people use on a daily basis for helping their web design?
