Subject: Skinning
pspeth
26 Feb 2008 4:13 PM
Some suggestions for further skinning updates.
1> adding a skin object that would automatically select font size, and page widths. (similar to that seen on the DNN site.
2> I looked at a skin that had a very robust layout.  Something like this:
      [                            Top Pane                                ]
      [            LeftPane         ][      RightPane               ]
      [ LeftPane2   ][   Contentpane   ][  RightPane2   ]
      [                         Bottom Pane                              ]
      [ LeftPane3   ][  Contentpane2  ][  RightPane3   ]
      [                         Bottom Pane2                             ]
  Of course this was created with tables, and  empty panes wouldn't show.
  It would give quite a bit of flexibility to the page creators without requiring multiple skins.
  - Is something like this a do-able extension of your latest skin using divs?
  - What are your opinions on this approach?
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
