Subject: OnyakTech Modules Review
edeakin
21 Jun 2008 1:31 AM
Lee,
            I want to develop a tech support website that I want to incorporate a CRM, Trouble ticket modules to assist support agents and customers with support issues.
            I was looking at the OnyakTech DNN Solutions (SigmaPro Draconis). Have you considered looking at these modules to give them a review?
http://www.sigmaprodraconis.com/
Keep up with the great work!
Fozzy
25 Jun 2008 5:16 AM
Thanks for the feedback, I had not considered looking at those modules for a review, but I will have a think about it. if you wish to find out more about the trouble ticket modules, I would ask the module developer if there is demonstration area that you could log in to and have a look, or a test trial version of the module.
