Subject: Zip Files
ktm200
17 Apr 2008 3:03 PM
Hi Lee,
First want to say thanks.  Being a developer but pretty new to dnn your videos have helped jumpstart my learning curve big time...
It would be alot easier when you have a group of lessons if you could package them in one zip file.  Its kind of a pain to download and indivdually extract six seperate files for one tutorial.  Especially since they are all so small.
My 2 cents
17 Apr 2008 3:29 PM
Thanks for the feedback, if you go to a main issue page and login, at the bottom of each issue page is a download zip file which contains all of the videos from that issue, this will help to speed up your downloads,
Lee
