Subject: not been able to download videos
sharad
02 Jul 2009 4:15 AM
My subscription not expired, and recently I tried to download videos. Instead it is asking for user login information. Please check.
Regards
sharad
02 Jul 2009 4:34 AM
This account does not appear as though it has had subscription access.
Please can you contact me direct via email for subscription enquries as I may miss enquiries placed in the forum.
Please email me your PayPal receipt and I can then look into the problem further, billing@dnncreative.com
03 Jul 2009 12:22 PM
Thanks for sending your info, I have checked your  details and the username with subscriber access is fss
sharad
05 Jul 2009 4:06 AM
Sorry I could not get. Or what do you mean by "subscriber access is fss
Regards
SK
05 Jul 2009 1:59 PM
You created a username: fss when you paid for the subscription, you can see the username on your invoice id.
I checked the username and it has full subscriber access. You need to login with the username fss.
Forums > Users Lounge > Membership > not been able to download videos
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
