Subject: Subscription
marila
31 Jul 2007 9:31 AM
I have paid subscription last Friday but I still can't download tutorials.I've send you two emails but still no answer.
01 Aug 2007 2:29 AM
Sorry for the delay, I have been away for a long weekend. For some reason PayPal did not automatically upgrade your account, so I have manually given you access. Hope you find the tutorials useful,
Lee
marila
02 Aug 2007 11:29 AM
Thank you
pcsandra
04 Feb 2008 7:17 AM
I have a similar problem, a few month ago(oct-07) , i subscribe to DNNCREATIVE and after a while i can download the videos and tutorial.  Now (feb-08) I'm trying to download new videos and they aren't availables.  i can't even find the links to watch or download the videos.
I even can see my name in the upper right corner of the display.
05 Feb 2008 9:19 AM
pcsandra, you have several user accounts registered on DNN creative.
The one with full subscriber access is username: pcsandy
Lee
Forums > Users Lounge > Membership > Subscription
