Subject: Subsription problem
coco323
19 Dec 2006 10:33 AM
Dear Sir,
I have subcribed through Paypal and I'm not abble to download any video, could you please check ?
Best regards,
Hervé
9 déc 2006  Paiement  A  LJS Media  Terminé   -£24,00 GBP  £0,00 GBP  -£24,00 GBP
19 Dec 2006 10:57 AM
You should now have full access to the website. For some reason PayPal did not upgrade your account so I have manually given you access.
Sorry for the delay, thanks,
Lee
coco323
19 Dec 2006 11:05 AM
Many thanks for your quick action.
Hervé
Forums > Users Lounge > Membership > Subsription problem
