Subject: Happy to join the community
hahnsolo123
05 Mar 2009 7:07 PM
I just joined today and paid for a membership. I just thought i would say hi to everyone and nice to meet you.  I hope everyone learns and achieves there goals
thank you
Michael
05 Mar 2009 10:59 PM
Welcome, Michael!
(May the force be with you!)
hahnsolo123
06 Mar 2009 12:12 AM
thank you
im reading the tutorials now
i went ahead of myself and tried the portal template but i had an issue on my own pc in which i set up the server using his ez to follow tutorial flawlessly with an error you cant set up a server with the email component not set up. I could probably put in fake stuff and may work but no biggie.
06 Mar 2009 7:40 AM
If you are referring to the SMTP setup, you don't (I think) have to set it up when you install. If I'm wrong, you can plug in information that is made up. You just won't be able to send emails from DotNetNuke.
Forums > Users Lounge > Membership > Happy to join the community
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
