Subject: How long after subscription is content available?
DanEckard
06 Sep 2006 10:55 AM
I subscribed and received and e-mail of successful subscription.  I then logged off and logged back on.  I still receive the message
How long does it take for the subscription to be recognized?
06 Sep 2006 2:01 PM
Hi Dan,
In most cases you get instant access. You didn't get instant access because you paid by echeque, which takes a few days for the payment to clear, and so Paypal didn't upgrade your access.
I have manually upgraded your account so that can get immediate access while your cheque is clearing.
Hope you find the tutorials useful,
Lee
RegGFX
14 Oct 2006 7:14 AM
I too have purchased via snowsnowcovered and received the email showing payment had been made. I sent the proof of purchase email as the zip file instructed. And registered as instructed... I also logged in and out several times.
And i still can't access modules....
Please advise and please help as soon as possible.
RegGFX
14 Oct 2006 7:25 AM
In the previous post i mentioned
I still can't access modules
I meant i'm not able to access videos even after sending my proof of purchase.
Still waiting and hoping.
15 Oct 2006 7:25 AM
RegGFX, you should now have full access. Apologies for the delay. When you purchase a subscription through snowcovered you do not get instant access as I have to manually upgrade your account on DNN Creative and I have been away over the past 2 days.
If you pay via PayPal on DNN Creative however you get instant access to all of the content as PayPal automatically upgrades your account on DNN Creative for you.
Hope you find the tutorials useful, thanks, Lee
Forums > Users Lounge > Membership > How long after subscription is content available?
