Subject: Video format
MattWeedenDesign
24 Jul 2008 7:46 PM
I'm a designer trying to learn how to build DNN skins, and everyone I've talked to recommends this site. Before I lay out the subscription fee however, I was wondering what format the video tutorials are in? I don't want to pay for files I can't open on my Mac.
Thanks in advance
Matt W
25 Jul 2008 7:43 AM
There is a free trial available on the subscribe page which will give you access to the latest formats that we are releasing, which are wmv and flash. - Flash should work fine on Mac.
All previous tutorials were released in flash video format, you can download a free one of those formats from this link:
Quick Start Guide to DotNetNuke
Forums > Users Lounge > Membership > Video format
