Subject: Good work
David Finley
31 May 2009 1:43 AM
Like the podcast each month. Keep up the good work!
David Finley
InteractiveWebs - DNN Module Development / CRM Integration
iwebs
dnnreader
03 Jun 2009 9:51 PM
Ye, podcast is excellent, it is great.
software reviews
04 Jun 2009 8:15 AM
Many Thanks, if you have any requests for topics to cover or people we should interview etc. Please let us know, thanks,
Forums > Users Lounge > Podcasts > Good work
Thanks for the reply Joe, The way my hosting company does things they don't have per say host hea...
RE: Flash in the HTML Module by robmacker
Wow, why does the forum format my question to make it basically unreadable?? I certainly did not typ...
Hello members! I have a simple flash application that was written for an HTML page and i'm trying...
Send email with Dynamic Forms Results by jesp17
Hello, Is there a way to automatically generate a report with all form results and then send this r...
Community Edition Question by idesofmarch
I'm learning a lot just browsing around here. Wish I could delete my question below. Oh well. Wher...
RE: DNN Site crashed after module install by mcmanta
I found a work around. Looks like the module replaces the Telerik.Web.UI located in the bin folder o...
RE: iHostASP by chandirika
Hi,I am reselling account with this http://www.goresellers.com/ site ,for my web site's web hosting...
the now content not showing and still showing the old one by wael_e
after i uploading the new contenct in my website and i uploading static html page have introdaction ...
RE: Regular Expression by jumatthey
Hi, Thank you very much Mark. It is indeed a name I am checking. Thank you for your help, very mu...
I think this website is properly structured in that I can drop the requirement to exclude certain pa...
RE: Nav Menu v2 for DotNetNuke v5 - Issue 52 by kparker
What are the advantages of setting the RenderMode to UnorderedList for the Nav Menu? How can this b...
RE: DNN Site crashed after module install by jncraig
Most likely, the module that you installed uses a Telerik library that is different from the one tha...
Hello All,I'm using DNN 5.2.3 after install everything was working fine. I installed the 365 Simple ...
Fun? with styling of Home.aspx by dkemp@karrtuttle.com
I asked my assistant to create a page for me and pursue an idea that I had for our intranet.  I thou...
Using Xenu Link Sleuth to Spot and Improve External Links in a Domain by Sh@wn
Hi,I have used this (useful) program in my dnn website and I have seen several page not found errors...
Thanks guys! So what are you using on this site?? Looks pretty much like the standard DNN regist...
RE: Regular Expression by MarkXA
Hi, For the case in point ValidationExpression="^[a-zA-z-' ]*$" should do it. I've added the hyph...
How to slow down the menu by datamark
Can you tell me how to slow down the solpart menu so that the mouse user can be a bit more sloppy ab...
It's a fine line between being too automatic and being too configurable.  It's awesome if Nav 2 indi...
DNN Creative Subscribe
