Subject: download video problem
Sakthi
25 May 2009 11:25 PM
hi
I am trying to download the video from dnn creative.
I have downloaded the video from download all the videos link for the following issues
Issue 1, Issue 2 , 3 , 4 and so on...
Issues 4 ,7 and 8 are downloaded fully. but when i try to unzip the file it is showing error message like "No file found"
can any one help me what could be the reason?
26 May 2009 6:01 AM
When I have come across users with this problem, it is usually because the download has not completed fully. It may appear that it has fully downloaded, but in fact it's missing a MB or so and therefore you get an error.
Could you try re-downloading those issues again and see if you can unzip them, I would suggest downloading one at a time, rather than queueing them all and downloading at the same time.
thanks,
Forums > Users Lounge > Podcasts > download video problem
That will work.
