Subject: Container height & alignment
Tony
19 Dec 2009 2:45 PM
 How can I
1) Align a contain to the bottom the page (HTML with a graphic that is always aligned at the bottom of the page
2) I have 2 containers on the right side of the page that can grow in height. One contains a data grid and the other a comments section. I wish to set those containers to a min height ( so if there are no entries the  the page/section don't 'collapse'
thank you
Tony
Forums > Skinning Toolkit > Skinning Toolkit > Container height & alignment
That will work.
