Subject: How to show disabled menu items differently in solpartmenu?
LSola
07 Feb 2008 2:28 AM
I am using solpartmenu control in my DNN site for navigation. Some of the pages are under development so I don’t want people to click the menu and view those pages. However I want those menus to show up as disabled menu item. Does anyone know how to get this working?
Nuke Master I
Nuke Master I
07 Feb 2008 9:18 AM
On the Page Settings for one of those pages, set the "Link" (under Advanced Settings) to point to the Home page or a dummy page. That will have the effect of making the menu entries inactive. You can change the Link to "None" to make the page active.
Forums > Skinning Toolkit > Skinning Toolkit > How to show disabled menu items differently in solpartmenu?
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
