Subject: Skinning toolkit access??
DrakenKorin
06 Feb 2008 1:17 AM
does a subscription to this site include access to the skinning toolkit?  If it does, I cannot log in to that site.  If it doesn't, all I can say is Doh!
06 Feb 2008 7:20 AM
The content of the Skinning Toolkit is completely free in that you can access it online without having to pay anything. If you want to download the actual pdf for quick access then a small fee is required.
I set it up this way this month so that I can distribute all of this information for free to the community without users having to subscribe to DNN Creative.
DrakenKorin
06 Feb 2008 7:31 AM
My bad, I should have noticed that the info on the site was accesible, I'm so used to sitting that side of the fence looking in, that I didn't even realise that the content on the skinningtoolkit site has been made freely available.
Forums > Skinning Toolkit > Skinning Toolkit > Skinning toolkit access??
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
