Subject: CSS and Browsers
nimroads
04 Oct 2007 8:00 AM
Hi All,
IE and Mozilla are showing the pages different (i.e. padding and position) which is normal.
Is there an easy way in dnn to use different style-sheets for different browsers?
Rob
04 Oct 2007 10:34 AM
Take a look at the Troubleshooting DotNetNuke Skins tutorial.
05 Oct 2007 10:41 AM
For stylesheets, I have implemented an IE only stylesheet in the Simple Red Leaf skin, it's demonstrated in this tutorial:
How to create a pure CSS skin
and again in this tutorial:
Pure CSS SEO Layouts for DotNetNuke skins
(check the videos that mention hacks)
nimroads
06 Oct 2007 6:03 AM
Thanks. I'll check it out.
tvanwynen
30 Apr 2008 10:36 AM
Lee, do you know of anyone who has created a commercial skin package using pure CSS?  I like your Red Leaf one, but I need to buy a package that I can get some support on. I a lone webmaster with too many hats to have time to trouble shoot a css skin.
01 May 2008 4:48 AM
I don't know of a commercial skin package, there maybe some on snowcovered, but I don't know what the quality will be. I've noticed some state "CSS skin" when they are referring to 'we have styled this using CSS, but used tables for the layout' - so you have to be a bit careful when purchasing CSS skins.
As well as the red leaf there are these skins available on DNN Creative:
Which may be helpful, of course if you need help, you can always ask in this forum, thanks,
ok great, glad to help,
