Subject: search box
Ericjr764
03 Oct 2007 1:09 PM
All i want to do i simply move the search box to the top of the screen.  Can anyone guide me on how to complete this..thanks
03 Oct 2007 1:50 PM
Sure ... it's fairly simple, but it's also complicated in the sense that you'll have to create a modified version of your site's skin.
To prepare for this, I'd recommend that you review the many tutorials here that deal with skin construction, and with Lee's "Skinning Toolkit."
But ... you want to step into the shallow end of the pool first, and not the deep end.  I'd recommend that you start with the tutorials that deal with the Red Leaf Skin.
And, if you are a relative newcomer to DotNetNuke, I'd recommend that you start with some of the tutorials for beginners that you'll find here.
ok great, glad to help,
