Subject: Fix Height Skin
gyfu
19 Mar 2007 9:16 PM
Lee,
       In DNN's tutorial for skinning, it is taught that we have a fix width skin. Is there a way to do a fix width and height?
I have been trying to do a fix height but did not succeed. I am using the table method to do my skins and pretty much followed your instructions through your skinning tutorial when creating the Vortex skin.
Please advise. Thanks.
20 Mar 2007 3:07 AM
it will be possible to do a fixed height, but if the content exceeds the height then a scroll bar will appear / or the content will not display / or the content will override the settings and display at the height it needs..
I haven't done this, but you could try adding for instance to the content pane CSS code with elements such as:
height: 200px;
overflow: scroll;
if you insert tables which contain height values it may override the settings and you may find it very hard to create a fixed height skin.
If this doesn't work, trying adding height values into the tables, good luck,
