Subject: Defferent CSS file for admin in DNN
databanq
02 Sep 2008 1:35 PM
My site looks good in both FF and IF, but I have some design issues when I'm logged in as admin in dotnetnuke. Is there a way to specify a css file which just going to be read when you are logged in as admin?
02 Sep 2008 8:10 PM
The easiest thing to do is specify a different skin (and a different CSS) file for administrative pages. But, when you do this remember that this will affect some pages that use the admin skin.
Forums > Skinning Toolkit > Skinning Toolkit > Defferent CSS file for admin in DNN
