Subject: Getting rid of a 1px space in IE
mtarby
22 Jul 2008 9:24 AM
I've been working on creating a mouseover effect for a HouseMenu - it works perfectly, but there's now a 1px space between the list items in IE that I can't get rid of.  Here's what I'm using to style my menu and the container its in.  Any suggestions of what I can try?
#navigation
    position: absolute;
    left: 0;
    top: 0;
    width:200px;
    background-color: #231f20;
    margin-top: -0.5em;
#navigation ul
top: 1.1em;
#navigation ul li
height: 40px;
list-style-type: none;
text-align: center;
background-color: #dfba39;
font-family: Garamond;
font-weight: bold;
font-size: 14px;
border: 1px solid white;
margin: 0;
#navigation a
    color: #000;
    text-decoration: none;
display: block;
padding-top: 10px;
padding-bottom: 10px;
#navigation a:hover
display: block;
background-color: #eed424;
#navigation ul li a.active
background: #7F8400;
I checked the source code that's being generated by the module and there's no space being added, so I'm a bit stumped.
23 Jul 2008 3:04 AM
When troubleshooting I tend to strip everything out of the CSS and then re-introduce it one at a time until the problem appears, you can then narrow it down to which part of the code is causing the problem in IE.
You may want to ensure all padding, margins, borders are set to 0 as a starting point and just see if you can get rid of the space without styling the menu.
mtarby
23 Jul 2008 2:48 PM
Thanks Lee - that did it. In case anyone runs into something similar, the gap in IE is caused by using display:block to create the rollover effect. All other browsers interpret it nicely, but IE treats it like a line break between my list items.
Forums > Skinning Toolkit > Skinning Toolkit > Getting rid of a 1px space in IE
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
