Subject: How to remove a skin package completely
mnguyen4311
01 Jul 2008 3:25 PM
Hello Forum,
I have installed a skin package, however, I know don't need it anymore in the portal.  Is there a clean way to completely remove the skin package from the portal?  Thanks.
02 Jul 2008 3:34 AM
Go to host menu / skins
In the skins drop down list, select the skin you wish to delete
Click on the delete skin package link
Forums > Skinning Toolkit > Skinning Toolkit > How to remove a skin package completely
