tag.
Does anyone have any experience with this?
Daniel
| 05 Jun 2008 3:04 AM | |
| Hello, It maybe worth looking at the Simple Red Leaf skin, this skin has a piece of Javascript inside the skin code, thanks, |
Lee Sykes Site Administrator Subscribe to the website : DotNetNuke Video Tutorials : The Skinning Toolkit : DotNetNuke Podcasts |
| 05 Aug 2008 3:30 PM | |
| how to add javascript to my Skins ? | |
| 07 Aug 2008 1:58 PM | |
| See the tutorial to which Lee referred. | |
| DNN - web services not working by paulrobinson |
| Good Afternoon,Please help. I have just installed my DNN web site to my dedicated live host machine... |
| [HOUSEMENU] token not working by whred5 |
| HiI have been playing around with the Lazy_Days skin in an effort to learn css based skinning, I hav... |
| RE: Building a website with DNN by freedom22 |
| Lee or Joe, I meant that the skin.css file I downloaded has classes like .main_dnnmenu_item td w... |
| Lee, thanks for your reply. I did find the files. I am going through your tutorail, and in video7... |
| RE: page publish date by leesykes |
| I would suggest you view these tutorials:User Accounts new features User Accounts and User Settings ... |
| RE: page publish date by jncraig |
| I'm not quite sure that I understand you, but ... on the user accounts page there are these options:... |
| RE: Best so far for me by jncraig |
| I like the Snapsis CSS Nav Menu. You'll find it at Snapsis.com. |
| RE: How to limit access to the admin menu.... by leesykes |
| Hello,Simply reverse the process, you can copy the settings from one of the other admin menu items t... |
| RE: How to limit access to the admin menu.... by tallorder |
| Shame about the parent page drop down being grey out since any Site Administrator is going to want t... |
| RE: Host and Admin user login not working on remote host by paulrobinson |
| A couple of quick questions: 1. Can I format the login page to the same as my other Text/HTML mo... |
| RE: Host and Admin user login not working on remote host by leesykes |
| Hello,Great, glad to help, have you had a look here for some SEO articles and interviews |
| RE: A question about permission? by leesykes |
| ok great, glad to help, |
| RE: A question about permission? by derpir |
| Your e-mail helped thanks I now have all my permissions set as they should. thanks |
| Lee, Thanks for your help on this - there was actually a character dropped off the end of the machi... |
| one question... After getting the permissions... Shouldn´t I be able to do all my development at... |
| RE: Solpartmenu and line breacks by leesykes |
| Hello,If you have a look in the CSS Reference Book p108Word-wrapThis is an Internet Explorer 5.5 or ... |
| Thank you Lee! I sent your reply suggestion and I hope they will understand better what I wanted fr... |
| hello,In order for DNN to operate correctly it needs full read and write permissions for the Network... |
| you will be able to register as a new user if the machine keys are incorrect, but can you login as a... |
| RE: centering a page in dnn by leesykes |
| Yes I have not come across a solution to that either and I think it occurs in all browsers.Thanks, |
