Subject: DNN Creative - swings a decision
Dave Hassall
23 Jan 2010 8:13 AM
For those people who use DNN commercially. When given a choice between an incumbent supplier and their proprietary CMS and using the "unknown" Dot Net Nuke being able to say “here is my tutorial base and support stream swung the decision”. Add to this the mass of ready modules on Snowcovered.com became a no brainer. Regards Dave
23 Jan 2010 8:14 AM
Cool!
Forums > Users Lounge > Testimonials > DNN Creative - swings a decision
Folder permissions by saintX
That will work.
