Subject: Nice one Lads - Lee, Joe and Rich!
mattb
12 Mar 2009 10:01 AM
Regards to Lee,Joe and Rich,
Just wanted to add my tuppence worth and say keep up the great work - I'll certainly be renewing my subscription when it's up for a second year.
DNNCreative is always my first port of call for all things DNN. Good, informative videos that I come back to time and again. Your "uploading to a live site" series really saved me time when I was up against a tight deadline.
Great to see you doing the vids on Dynamic Forms - like me you obviously recognise what a great module that is. Combined with CataLOOK (and DNN itself of course!) it enabled me to get my first 4 DNN sites up and running relatively quickly.
Good tools are nothing without the right people behind them explaining there "in's and out's" and you boys at DNNCreative certainly do that.
Keep up the good work and all the best
Matt
Brentwood,UK
12 Mar 2009 12:26 PM
Cheers, it always makes my day when I read comments like this!
Forums > Users Lounge > Testimonials > Nice one Lads - Lee, Joe and Rich!
Module Advanced Setting by booth
I need to understand the operation of the “Display Module On All Pages ” control on the setting page...
Efficient Contacts Manager by etadmin
Currently I'm using the Forms and List module, it has about 1500 contacts and 40-50 fields per conta...
RE: How to do links? by leesykes
I think the easiest way to set this up would be to use the default NAV Menu that comes with DNN. It ...
RE: DataSprings / Aweber by leesykes
Yes you probably used an IFrame over a HTML file which included the form, IFrame still exists.Here i...
RE: ITextSharp by leesykes
thanks for the info
and for the Aweber section you should be able to setup a Form completion event on that form which se...
You shouldn't have to delete and recreate. The internal (to DotNetNuke) addressing is handled by th...
I think I have figured out the answer myself. In my host is something called A Records. This is equ...
RE: Saving site settings error by jncraig
When you say that you "published" the site, do you mean published from within Visual Studio?I'd reco...
RE: Regular Expression by jncraig
Google for "Regular Expression Library" and search around. You should be able to find something tha...
RE: Change Registration Redirect? by jncraig
Dynamic Registration will permit you to use a "redirect after login" page.
RE: Removing View and Edit Buttons by jncraig
Most likely, the View and Edit buttons are there because either the page or a module on it has edit ...
RE: Removing View and Edit Buttons by jumatthey
o.O ... weird. This should only display if you are logged on as admin or host.
RE: Removing View and Edit Buttons by mikehj
I was able to remove the register in admin settings and I had already gone into the skins file and m...
Can you post a screeshot of what you are refering to more precisely ? Thanks. I personnaly remove...
Regular Expression by jumatthey
Hey all.I need to find out a regular expression for a DotNetNuke module I am building.This is my ASP...
RE: ITextSharp by jumatthey
The key line was this one : PdfWriter.GetInstance(document, new FileStream(HttpContext.Current.Se...
I have removed the Register and Login controls from the default page. I still have the Edit and Vie...
Saving site settings error by directaccess
Hey folks, Recently started looking at DNN. And did some nice tests out of VisualStudio using the...
Then again, I have a problem leaving things too simple. I will link to Aweber, most likely u...
