Subject: Feel the need to say - Thanks so much
Craig Lambie
21 Feb 2009 2:06 AM
Hi Lee, and the team!
I just wanted to say thanks, I have been using DNN for about 6 months now, and I rarely need to go elsewhere for an answer.
Your magazine is fantastic, up to date, and an amazing source of information.
Thanks so much!
C
Craig Lambie
Forums > Users Lounge > Testimonials > Feel the need to say - Thanks so much
That will work.
