Subject: I am a new member...
dpbklyn
13 Jan 2009 11:42 AM
...and this is the best site I have found.  I have subscribed, posted and resolved many, many issues and I have only been working with DNN for about a week!
Well worth the investment!
Forums > Users Lounge > Testimonials > I am a new member...
That will work.
