Subject: Brilliant! Clear instructions from the very start
seniah08
20 Feb 2008 3:43 PM
I can not tell you how good this site is. I am a beginner to all this with miminal experience in using a wysiwyg page editor. This site goes thru all the basics and as far as I can tell I am going to be using its resources for a long long long time!
Thanx so much Lee (gush,gush)
Sam from The Seniah Group Australia
www.seniah.com.au
Forums > Users Lounge > Testimonials > Brilliant! Clear instructions from the very start
RE: right alignment of paragraph in text or html module... by meenu
thank u so much ...... i done this based on ur suggestion... regards
Skinning the store checkout by icaustonltd@hotmail.co.uk
Dear all,I have installed the default store module but I have noticed that the checkout will only sh...
Replacing the DNN Core Search Engine by Declic Video FX
Hello Lee,I would like to replace the DNN Core Search engine, because I have lots of problem with it...
RE: Store Module Paging by davidrushton
Hi Lee, Thanks for your reply. I have just modified the database directly setting the store page...
RE: Site for review by host_critics
Hi there,Could you please also review http://www.asphostcentral.com?
RE: PinesSoccer.com by Feoj
Hey Tex, First let me congratulate you on doing a great job on www.PinesSoccer.com. You obviously h...
Stop spam-bots from collecting emails off your site! by andyb1979
Ok, so I find every time I put a mailto: link in my website, spam bots go mental and start filling u...
Sites without menus - make menu visible to admins only by andyb1979
I'm developing a simple two-page site at www.bigmatch.org.uk. Because its so simple, It doesn't need...
RE: currency settings by mparrett
ah yes, i was on the older moduler have upgraded and it works fine! thanks
RE: web app shut down diagnosis by leesykes
Hello,That's great, thanks for taking the time to post all of this information, I'm sure people will...
RE: currency settings by leesykes
So you have gone to the admin menu  / site settings / advanced settings / payment settings and selec...
RE: how do I allow access to downloads after checkout by leesykes
Hello,No this is not possible with the store module, you can do this though:How to set up DotNetNuke...
RE: Store Module Paging by leesykes
Hello,I have just setup a test store how you have described and I can replicate the problem. This ap...
RE: Not Really A DNN Question by mgordon
RE: Not Really A DNN Question by jncraig
No, I think that will break things. The requests should be forwarded to the DotNetNuke installation...
OK, but where do the Host Headers in IIS come in?I've contacted the county and they are going to add...
Yes. If they manage your DNS, they are the ones with whom you will have to deal. Tell them that y...
Hi Joe,That's where I'm being thrown for a loop...setting up the DNS.  I'm with the county and do  n...
Mark, All that you need to do is create the second site, and it can be either a child site or a p...
ihostasp
