| Skinning the store checkout by icaustonltd@hotmail.co.uk |
| Dear all,I have installed the default store module but I have noticed that the checkout will only sh... |
| Replacing the DNN Core Search Engine by Declic Video FX |
| Hello Lee,I would like to replace the DNN Core Search engine, because I have lots of problem with it... |
| RE: Store Module Paging by davidrushton |
| Hi Lee, Thanks for your reply. I have just modified the database directly setting the store page... |
| RE: Site for review by host_critics |
| Hi there,Could you please also review http://www.asphostcentral.com? |
| RE: PinesSoccer.com by Feoj |
| Hey Tex, First let me congratulate you on doing a great job on www.PinesSoccer.com. You obviously h... |
| Stop spam-bots from collecting emails off your site! by andyb1979 |
| Ok, so I find every time I put a mailto: link in my website, spam bots go mental and start filling u... |
| Sites without menus - make menu visible to admins only by andyb1979 |
| I'm developing a simple two-page site at www.bigmatch.org.uk. Because its so simple, It doesn't need... |
| RE: currency settings by mparrett |
| ah yes, i was on the older moduler have upgraded and it works fine! thanks |
| RE: web app shut down diagnosis by leesykes |
| Hello,That's great, thanks for taking the time to post all of this information, I'm sure people will... |
| RE: currency settings by leesykes |
| So you have gone to the admin menu / site settings / advanced settings / payment settings and selec... |
| RE: how do I allow access to downloads after checkout by leesykes |
| Hello,No this is not possible with the store module, you can do this though:How to set up DotNetNuke... |
| RE: Store Module Paging by leesykes |
| Hello,I have just setup a test store how you have described and I can replicate the problem. This ap... |
| RE: Not Really A DNN Question by mgordon |
| Right on. Thanks, as always, for your help! :-) |
| RE: Not Really A DNN Question by jncraig |
| No, I think that will break things. The requests should be forwarded to the DotNetNuke installation... |
| Or do I even bother with the Host Headers in IIS if DNS is updated? |
| OK, but where do the Host Headers in IIS come in?I've contacted the county and they are going to add... |
| Yes. If they manage your DNS, they are the ones with whom you will have to deal. Tell them that y... |
| Hi Joe,That's where I'm being thrown for a loop...setting up the DNS. I'm with the county and do n... |
| Mark, All that you need to do is create the second site, and it can be either a child site or a p... |
| But I am hoping you've addressed this in one of your tutorials.I need to have a subdomain/child port... |
