Subject: One Year Now, and gladly signing up for a second!
DavidWSnow
22 Oct 2007 10:54 AM
Last November when I started using DNN as a platform for our business web site I signed up for a DNN Creative Magazine subscription reluctantly. I had tried several for-pay DNN tools and been disappointed with them. I figured that since I got access to all of the old videos, I had a better chance of getting value for my one year subscription and it was worth the gamble. I was sure that I would only want this service for just one year.
Well that year is now up, and the price has gone up.  However I didn't think twice about signing up for a second year. I get way more than my money's worth each month. I have gotten more useful skins for our business site from DNN Creative than I got from a site that  sells skins! The technical articles are informative and accurate. In fact, when I found a shortcoming in one, Lee had the skin and the video redone within a day or two. I have a better chance of getting a answer to DNN questions in DNN Creative’s forums than I do in DotNetNuke’s forum.
Dave Snow - a very satisfied customer.
23 Oct 2007 10:31 AM
wow thanks Dave, your comments are really appreciated, cheers,
Lee
Forums > Users Lounge > Testimonials > One Year Now, and gladly signing up for a second!
module spacing by njmertz
Right now I am creating a site for a school using DotNetNuke Version 4.8.4. On the left side of the ...
domain name change search by rogerg1967
Hi,I have a site which I want to keep the same but change the domain name on. I have duplicated the ...
RE: Need help for Efficion Consulting Article module by smyagnik
hi craigthanks for your replyi check all the settings but there is no option like thati want cuz i w...
RE: Restoring Live to Local by joannew
Error with Nuke News Module fixed by editing Controls/TextEditor.ascx changed to  http://www.codefla...
RE: Reseller Choice by Alavri
I just purchased a 25 domain plan with Re-Sellers choice and I am very impressed  with how fast and ...
RE: How Do I Change the Menu Font Color??? by usheen
We have been using Snapsis Nav Menu mainly because the SolPartMenu is a mess in both CSS/HTML and SE...
RE: How Do I Change the Menu Font Color??? by sydcam
Thank you for your quick response. I will give this a try. Do you know of a good menu module? I m...
If you are using Firefox I would advise getting the Firebug addon installed. Once you have done that...
RE: Development versus Live Portal Issue by usheen
Joe,You are correct, I was trying to change the Portable option in the Module Defintions for some of...
Hi,I'm new to DNN and I'm developing a new skin from scratch.  I need to know how to change the colo...
My first website is currently running in a browser and the. login is okay but some modules show erro...
Okay, I've now got a version working locally I think these instructions helped: ...In the web.con...
thanks for the advice, I was just about to do it... so how do you turn the authentication on?
RE: adding javascript to skin by jncraig
See the tutorial to which Lee referred.
RE: i need module for display quotes Randomly by jncraig
I've seen a module that does this. Go to Snowcovered and search for "quotes" and you'll probably fi...
RE: Restoring Live to Local by jncraig
If your SQL server isn't configured to do user/password authentication, you can turn that on. You d...
I think my problems are to do with the web config and database user name and password but also becau...
Thanks for your reply... For my first site, I can look at the connection settings (does this mean I'...
RE: Development versus Live Portal Issue by jncraig
OK, I read this. I take it that you are trying to alter module settings on the host's Module Defini...
RE: Firefox has detected that the server is redirecting the request for this address in a way that will never complete. by jncraig
Usually, I find that this is related to the portalalias table. Have you recently made some changes?
