Subject: Great Resource
rodriguez
02 Oct 2007 11:12 AM
DNNCreative provides easy to understand, excellent tutorials; best bang for your buck if you're shopping around for comprehensive DotNetNuke resources!  Active, dedicated forum community to help you out!
Forums > Users Lounge > Testimonials > Great Resource
How to do links? by Guy..L
How to close a website while you are working on it by mcmanta
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ...
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tri...
Yes, that is the one.
Thanks for the tip. I will let my programmer check it out. This is the module you're referring t...
RE: extending user accounts for membership by jncraig
Try these:User Accounts new features User Accounts and User Settings Enforcing Terms and Conditions ...
RE: DataSprings Dynamic Forms Demo #20 Question by jncraig
There are some nice examples on the Data Springs site.  The more complicated demos do require some s...
RE: Dynamic Forms Email From User/Pass by jncraig
If the SMTP server is configured so that it will not send email from arbitrary email addresses, I wo...
Glad that you got it solved.There is a free module available from Iowa Computer Gurus that automates...
