Subject: ~ Fantastic Tutorials ~
julianmummery
01 Oct 2007 8:45 AM
Lee,
Your tutorials are of top quality and extremely professional!
They have helped me a great deal.
In fact they have saved me hours upon hours of mucking around with DotNetNuke just to try things out.
Just wondered what software you use to capture the tutorials with, I love the bounding boxes around the relevant parts of the screen that you are discussing.
Regards
Julian Mummery
01 Oct 2007 2:13 PM
Glad to hear you find the site useful, the software is adobe captivate - we spend a lot of time though editing the videos for them to look like that ;-)
Forums > Users Lounge > Testimonials > ~ Fantastic Tutorials ~
Member log in by HUGHD37IUOE
Video Problem by icdlbake
