Subject: very, very, very good
cartland
05 Mar 2007 12:04 AM
excellent even .
I don't know how many articles, etc I've read where the writer is assuming some degree of background knowledge or contextual understanding. I spend frustrating hours/days/weeks filling in the blanks before I "get" what the author was saying - then it seems obvious.
The tutorials & videos here spell it all out and take the pain away from learning DNN. It actually becomes enjoyable and I appreciate DNN a whole lot more.
This site does an outstanding job of succeeding in what it sets out to do - educate about DNN.
bruce
Forums > Users Lounge > Testimonials > very, very, very good
