| extending user accounts for membership by cbwardsr |
| could someone pt me in the direction of some literature regarding adding fields to user accounts.
| RE: Strange behaviour when pressing login by pontus66 |
| Problem solved!Though I am not sure how. I haven't talked to my programmer yet, but he sent a mail a... |
| Dynamic Forms Email From User/Pass by Trusted |
| Hello everyone,
We have a client with restrictive mail policies so a username and password is requi... |
| Using Default Template for Pages by toddre |
| I have a default template that I would like all Admins to use when creating new pages. I would also ... |
| RE: DataSprings Dynamic Forms Demo #20 Question by aggiedan97 |
| Thanks for the feedback. I will let you know what I find and I have posted on the DS forum. So far ... |
| RE: ITextSharp by leesykes |
| Glad you got it sorted, what was the solution for anyone else searching for this problem? |
| RE: DataSprings Dynamic Forms Demo #20 Question by leesykes |
| Hello,This is not something I have explored yet, but as it happens I am going to be building a form ... |
| I am attempting to build an order form that subtotals a section that is based on the 'TotalByQuan&nb... |
| RE: Shared Same content in Sub portals/ Childportals by leesykes |
| Hello,Your other option is to use RSS feeds for sharing content. Setup a module on your main site su... |
| RE: Should I be able to use a plain submit button in my module? by DiscoStu1975 |
| Hi I used an ASP:button control originally and that produced exactly the same error with JS disa... |
| RE: Strange behaviour when pressing login by jncraig |
| Hmmm, I think that I have seen something like this before, but I'm having trouble remembering the ex... |
| RE: Shared Same content in Sub portals/ Childportals by jncraig |
| There are modules available that will permit you to share pages, modules and user among portals in a... |
| RE: Should I be able to use a plain submit button in my module? by jncraig |
| Using a form submit button won't work. If you use an ASP:button control that will work as clicking ... |
| Hi Joseph Thanks for the response. I am using an html input of type submit, yes. When you say a l... |
| Are you using a form submit button? Try just just using a link and see if that works. |
| RE: Removing the filed by jncraig |
| I don't know an easy way to do that, short of editing the ascs file that displays that information. ... |
| RE: ITextSharp by jumatthey |
| Problem solved. |
| Removing the filed by kaustav_kar |
| Hi,I want to remove the option Display Name from this page. http://whydiet-com.stagemefaster.com/hom... |
| I have developed a module that is basically a simple data capture form. As I need the form to work w... |
| RE: Links by rajanijadhav |
| I have another question,in paypal integration for payment i have used [script removed] |
