Subject: Nav menu skinning
Fredrik
01 Feb 2010 4:04 AM
I have been looking around the Internet for some good tutorial about nav menu skinning.
Your site always came up on top in the google search.
After a few days I thought ok I'll give them a try.
I started with the DotNetNuke Nav Menu v2, Custom Login Module OWS, Styling App with RAD tutorial.
In the beginning of the tutorial you recommended that I'd what a previous tutorial about the NavMenu to be familiar with the basics and in that tutorial you recommended that I should watch yet another tutorial.
So I did.
This was the best thing I have ever done in my entire career as a web developer.
The tutorials where as perfect as they can be. I love the tempo in them, I love the how you describe everything without going in to what happened back in the day (which is a sickness amongst IT people usually).
You described how everything works in a way that suited me better than I could ever dream of.
I finally understood that final missing piece I have had gnawing in th back of my mind about the thought of DotNetNuke.
This was by far the best value for money I have ever experienced in my entire life!
I went around smiling the entire weekend and talked about your tutorials to everyone I met.
I can't wait to continue with the other tutorials.
Best regards
Fredrik
01 Feb 2010 4:12 AM
wow thanks, it always makes my day to hear feedback like this, I can now go around all day smiling as well ;-)
Forums > Users Lounge > Testimonials > Nav menu skinning
Folder permissions by saintX
That will work.
