Subject: DNN Creative - swings a decision
Dave Hassall
23 Jan 2010 8:13 AM
For those people who use DNN commercially. When given a choice between an incumbent supplier and their proprietary CMS and using the "unknown" Dot Net Nuke being able to say “here is my tutorial base and support stream swung the decision”. Add to this the mass of ready modules on Snowcovered.com became a no brainer. Regards Dave
23 Jan 2010 8:14 AM
Cool!
Forums > Users Lounge > Testimonials > DNN Creative - swings a decision
RE: How to Create an Email Form with OWS - Issue 49 by CelesteT
Hi, Was also wondering if there was a way to incorporate ReCaptcha (www.recaptcha.net) into the emai...
Hi, Thanks for the great tutorial. I was wondering how I can hard code a "to" email address into th...
That will work.
