Subject: K.I.S.S Works everytime
Dave Hassall
06 Jul 2009 6:57 AM
I have been using DNN for some time, and been looking to expand my knowledge and do some Module maintenance and development. The bit holding me back was to get a working development environment.
I had seen and used other video tutorials but to no effect, they made it too complex, configuring IIS and SQL Server.
I followed the tutorial on this site and Hey! Presto it sprang into life.
I'm starting my hourney but completely love the video tutorials I've watched so far.
Keep It Short and Simple - works everytime
Many thanks
Dave
P.S. Possibly the best £50 I've spent in a long time
Forums > Users Lounge > Testimonials > K.I.S.S Works everytime
RE: Send email with Dynamic Forms Results by jesp17
Hi Lee,I've asked DataSprings if there is a way to solve my problem (wish). Here is a reaction:I don...
Background Music by kparker
Do you know of any module that I can use to play background music on a single page?  Or do you have ...
I did this several years ago, so I think that what I found must have been in the "Professional DotNe...
RE: Server Error in '/' Application. by michellb
Here is the entire text on the page: Server Error in '/' Application. Runtime Error Descrip...
