| while installing bulk emailer module in my website by agiline |
| Hi all,i have downloaded bulk e mailer trial version and when i am installing it in my website it wa... |
| RE: Creating Portals before setting the host by cyborama |
| Hello Joe, Just got done speaking with my hosting company in reguards to A records and host head... |
| RE: PayFlow Link by johnmurphy |
| Hi murphydolores,
I am using iHost. iHost.Net supports PayFlow Link and its easy to configure. T... |
| RE: Background Music by cyborama |
| Hello Kyle I can't think of any modules that could do this though that doesn't mean they are not out... |
| Hello Joe thanks for the quick reply, If you read down my thread fully you will see I had already... |
| RE: Employee Absent Indicator by jncraig |
| I think that the biggest here is to define the workflow and to figure out who/how will maintain the ... |
| RE: Run exe/dll from DNN? by ollivogt |
| Thank you. I have a look at it....RegardsOliver |
| RE: DotNetNuke 5.3.0 Released by jncraig |
| Whoops!
From Joe Brinkman: "With any software product you will occasionally have a release tha... |
| RE: Creating Portals before setting the host by jncraig |
| Whoops! Didn't quite finish.
DNS, through A Records and other records is used to convert a domai... |
| NO! Don't delete and start over. "A Records" are part of DNS. Host Headers are part of IIS Co... |
| By the way Lee or Joe didn't try this yet but do you think it would be wise (should someone else run... |
| Ok Lee, Joe, and others reading this thread, I just had success. Here is what happened. I thoug... |
| Hello Lee, No Success yet I think I might need to delete my portal and recreate it. I created th... |
| RE: Auto create pages and content by jncraig |
| Are you using the DotNetNuke menu or another one? |
| RE: Missing Edit & Add Function on Modules to Entire Site by jncraig |
| Glad it's working! |
| RE: Firefox SWF file by jncraig |
| I recommend that you use the free DigFlash module from dignuke.com. I've found it to be a very reli... |
| Firefox SWF file by ce221 |
| on my dnn site it have a text/html that has the following attached code this displays fine in IE but... |
| RE: Missing Edit & Add Function on Modules to Entire Site by jacksonsc56 |
| arrrrggghhhh for goodness sake, I was in View mode!.
After a year working on numerous B2B DNN sit... |
| Strangely enough the Admin account is displaying the modules settings menu. To confirm its the menu ... |
| .MainMenu_MenuItemActive (Active Solpart menu item not working) by SixfootStudio |
| Hi Guys,
Could someone please take a look at this SolPart menu for me and tell me why it is that ... |
