Subject: Awesome!
wynnjon
01 Oct 2008 8:48 AM
I feel most, if not all of my questions were answered through my membership at dnncreative.com.  It has become my favorite site as of late.  Lee does a great job demonstrating, not only the base functionality of DNN, but many different ways you can get the most out of your DNN install and associated modules.
What's fun about it-- the name "DNN Creative" actually does this subscription justice.  Lee shows us ways of using DNN that I had not considered.  I purchased the membership primarily for the "How to control access to the Admin menu" video- and was not sorry!  Now I am well on my way to becoming a DNN pro-  fo real!
Thanks Lee!
Module Advanced Setting by booth
I need to understand the operation of the “Display Module On All Pages ” control on the setting page...
Efficient Contacts Manager by etadmin
Currently I'm using the Forms and List module, it has about 1500 contacts and 40-50 fields per conta...
RE: How to do links? by leesykes
I think the easiest way to set this up would be to use the default NAV Menu that comes with DNN. It ...
RE: DataSprings / Aweber by leesykes
Yes you probably used an IFrame over a HTML file which included the form, IFrame still exists.Here i...
RE: ITextSharp by leesykes
thanks for the info
and for the Aweber section you should be able to setup a Form completion event on that form which se...
You shouldn't have to delete and recreate. The internal (to DotNetNuke) addressing is handled by th...
I think I have figured out the answer myself. In my host is something called A Records. This is equ...
RE: Saving site settings error by jncraig
When you say that you "published" the site, do you mean published from within Visual Studio?I'd reco...
RE: Regular Expression by jncraig
Google for "Regular Expression Library" and search around. You should be able to find something tha...
RE: Change Registration Redirect? by jncraig
Dynamic Registration will permit you to use a "redirect after login" page.
RE: Removing View and Edit Buttons by jncraig
Most likely, the View and Edit buttons are there because either the page or a module on it has edit ...
RE: Removing View and Edit Buttons by jumatthey
o.O ... weird. This should only display if you are logged on as admin or host.
RE: Removing View and Edit Buttons by mikehj
I was able to remove the register in admin settings and I had already gone into the skins file and m...
Can you post a screeshot of what you are refering to more precisely ? Thanks. I personnaly remove...
Regular Expression by jumatthey
Hey all.I need to find out a regular expression for a DotNetNuke module I am building.This is my ASP...
RE: ITextSharp by jumatthey
The key line was this one : PdfWriter.GetInstance(document, new FileStream(HttpContext.Current.Se...
I have removed the Register and Login controls from the default page. I still have the Edit and Vie...
Saving site settings error by directaccess
Hey folks, Recently started looking at DNN. And did some nice tests out of VisualStudio using the...
Then again, I have a problem leaving things too simple. I will link to Aweber, most likely u...
