| RE: Permissions Question by BCRose |
| Does that involve editing the source code? May not be too big of a challenge to you but that is som... |
| RE: Skin missing banner and menu when ctl is used in the url by jncraig |
| Is this fixed now? |
| RE: Permissions Question by jncraig |
| Well, thinking about it ... it would not be too big of a challenge to take the module, remove the fe... |
| Ummm...too bad. That seems like a no-brainer for this module. |
| I don't believe that's possible. I'd love to learn that I'm wrong. |
| Ok, Thanks for the info. I was able to make those changes, Now...I want this user to be able to ad... |
| In DotNetNuke 5.x, you have control of permissions on the Admin and Host pages. So, you can grant p... |
| Is it possible to give a user permission to add and delete users, change pw's etc. without giving th... |
| RE: daisy chain continuous loop of all the flash files by mlorence |
| I made a test html page in Dreamweaver and it works perfectly, just as it does on my desktop. I u... |
| RE: Skin missing banner and menu when ctl is used in the url by swelch |
| Sorry about that. That was my test domain and I just switched it to the permanent....http://www.neb... |
| Strange behaviour when pressing login by pontus66 |
| Hi,When pressing Login (Sign In) on one of my clients portals the adress for the homepage gets sort ... |
| RE: My site is down by proarch123 |
| Thank you Lee Sykes |
| RE: daisy chain continuous loop of all the flash files by jncraig |
| I would imagine that each file includes a URL to other link to the next file. That works fine on yo... |
| RE: Install Skin Error Message by jncraig |
| Where did you get this skin? It seems to be missing a file, license.txt, that is a required element... |
| RE: domain name by aventhika123 |
| Hi, for expected Domain name use this http://www.xnynz.com/ site ,here only i got my all sites doma... |
| RE: How to Create a Custom Login Module with OWS - Issue 52 by kana |
| I modified Your example with one thing - looking for enter key on password field. I added that in Re... |
| Install Skin Error Message by Captain Canary |
| Hi
When trying to install a new skin via Extensions with DNN v 5.2.3 I get the following error m... |
| RE: OWS Query Template Results by VickySwift |
| Hi,
In the end I achieved what I needed with IIF statments and ALTERNATE
Pretty sure its not the... |
| RE: Login problem with other browsers than IE by kana |
| I added alert(); into onkeypress and now after I press enter on messagebox page is forwarding fine. ... |
| RE: OWS Query Template Results by kana |
| I don't know, that is possible, but I would try to use javascript in dteial template to build string... |
