Subject: Site Review: Mylec Sports
edegagne
13 Nov 2007 2:32 PM
Another site I just released, figuered I'd again get your opinions....again.
www.mylec.com
Mylec Sports is the parent portal, Mylec Hockey and Mylec Dekmat are child portals. All 3 share a common layout/theme.
This was a different approach in that I purchased a skin (Flux - Tyler Fawcette) and modified it slightly for the client.
Client is happy.
Thanks in advance.
Forums > Users Lounge > Site Review Please! > Site Review: Mylec Sports
ok great, glad to help,
