Subject: World Wide SQL Server Community Portal
Shakani
30 Sep 2007 4:00 PM
Hi DNNCreative members,
Could you please review www.sqlcommunity.com website and provide me with your feedback.
Thank you,
Saleem
digmike
30 Sep 2007 4:21 PM
Hi Saleem,
As far as content, it looks like you got a good start.  I like the scripts repository, that's a great idea for a sql community!  The look is just like the DNN default skin, which isn't too nice to me.  I would go to snowcovered.com and buy a nice skin for $70 or so.  I also feel like there is too much information other than the actual subject on each screen.  Alot of items keep starting with "SQL Server" Discussions, QuickLinks, blogs, etc..  You have some great ideas, I just think the presentation needs cleaned up a bit.  Oh yea, you need a sexy logo.  Go to namepros.com, you can start a logo contest for $30-$50, and you can have a bunch of people submit logo ideas.
Good Luck,
Mike
dignuke.com
Shakani
30 Sep 2007 4:30 PM
Thanks for your feedback Mike, any skin that you can suggest from snowcovered.com? I'll go ahead and get a logo from Namepros.com. any tips and tricks for search engine optimization?
Thanks very much for your feedback.
Thank you,
Saleem
Forums > Users Lounge > Site Review Please! > World Wide SQL Server Community Portal
