Subject: Here's a web site for you to beat up on!
topoulos
08 Sep 2007 12:08 PM
www.reelholes.com
It's a movie review site.
let me know what you think!
Tony
10 Sep 2007 5:24 AM
Looks good, the styling of the news articles module integrates well with the design.
There are two points you may want to consider: 1) it took a while to load on the initial page loading, so you may want to consider using an uptime tracking service to regularly ping your website every five mins just while the traffic is building up on your website. - An example is: www.host-tracker.com - this will keep your DotNetNuke site in the servers memory and so on first page load it will be quick.
2) you may want to consider using header tags for the titles, I have implemented this within the news articles module on DNN creative, have a look at the source code of this page: http://www.dnncreative.com/Reviews/tabid/58/Default.aspx - I have discussed semantic coding in this tutorial: Semantic Code and Header Tags in DotNetNuke Skins
topoulos
10 Sep 2007 4:14 PM
Lee, you rule. I learn something new every 5 seconds on this site.
Quick question on the hosting at host-tracker: which account type would I need to sign up for to set the interval for every 5 minutes?
Tony
11 Sep 2007 2:18 AM
Ah, Host-tracker were free when I was using them, another site I have seen recommended in the forums is:
http://www.mon.itor.us/
I haven't tried it yet, but would give it a go as it's completely free.
Cheers,
Forums > Users Lounge > Site Review Please! > Here's a web site for you to beat up on!
