Subject: Give your feedback on our NetPotential DNN site..
jellyweb
19 Jul 2007 3:29 PM
We've fairly recently launched our own new site in DNN, and are currently using DNN whenever possible (mostly!) for our clients' websites.
Please check them out and let us know your thoughts.
PS. Well done Lee on producing/providing a great DNN resource!
Most sites use the HouseMenu, and are CSS based designs.  With some optimisation tweaking we're really happy with the load speeds compared to our earlier DNN sites.
www.netpotential.co.nz (our site)
www.mjmurphy.co.nz
www.pacificdive.co.nz
www.taradalemedical.co.nz
your feedback is appreciated...
Many thanks,
Tim
Forums > Users Lounge > Site Review Please! > Give your feedback on our NetPotential DNN site..
