Subject: My Very First DNN Website.
davidjimrie
28 Mar 2007 1:49 AM
Hi, below is a link to my very first Dotnetnuke web site. it has taken me and my partner in crime a couple of months to complete. we are using catalook as the shopping cart. As most of our friends and family love it, we are unsure of what the real world would actually think. please share your thoughts... https://www.citysaint.com.au/Default.aspx
bryantklh
28 Mar 2007 4:22 AM
dude, i have view your site, i love that too, pretty simple and clean, thats good enough.
i don't know i gotta spend how long to create a nice site like yours.
anyway i m newbie, jz downloaded dnn last night.
10 Apr 2007 6:10 AM
Yes looks good. - The one thing that would be worth looking at in terms of usability is that you can't click on the pictures, for instance on the home page the first thing I wanted to do was click on the images where it states 'visual clarity', 'blue-Ray', 'sound clarity'
and also here you can't click on the images, you have to click on the text.
https://www.citysaint.com.au/ForHome/tabid/148/List/0/Default.aspx
I would look at this because in your main content area where the eye focuses on there are no links to take you into the products of the website.
gymnasticsmedia
10 Aug 2007 9:24 AM
CitySaint looks great, and a very cool concept.
I am getting a popup as soon as I hit the front page.
"This page contains both secure and nonsecure items."
"Do you want to display the nonsecure items?"
Screenshot of the Pop Up.
GymnasticsMeida.com
The Ultimate Portal for the Ultimate Sport
Forums > Users Lounge > Site Review Please! > My Very First DNN Website.
