Subject: Site review please
HUGHD37IUOE
04 Oct 2008 7:21 AM
We are interested in any suggestions for improving our new site: www.iuoe.org
10 Oct 2008 9:25 AM
The site looks good, clear and easy to read, it took me a while to find anything for improvement, but here they are:
1) Text size is fixed, it may benefit from allowing users to increase the text size when in IE
2) a print stylesheet, take for instance
http://www.iuoe.org/OurLocals/tabid/54/Default.aspx
This looks messy if you print preview it, you can find further information on working with print in DotNetNuke here:How to Create Print Stylesheets for DotNetNuke Skins
overall, looks good,
Forums > Users Lounge > Site Review Please! > Site review please
